The platform by Elipse Software was updated to improve process monitoring, thus optimizing the generation of indicators and real-time data analysis
Elipse Software has updated its platform for digital transformation and real-time data management. Elipse Plant Manager (EPM) version 7.0 is brimming with new developments. Now, calculated properties (expressions) can be added in real time to EPM Model. Therefore, users are no longer required to create external algorithms to execute the simple task of calculating the indicator associated with its assets.
propriedades-calculadas
Expression Properties at EPM Model
Another update for this version is the Elipse MCP Connector, a service by Elipse Cloud, through which EPM users are able to interact with different LLMs (Large Language Model) (AI agents). With this interaction, users can question the LLM about data in the EPM application and even connect it with data from other sources.
The latest version also allows choosing the information bits to be displayed as tooltips, that is, the information displayed when the mouse cursor moves over pens in EPM Portal’s charts. And for improving visibility, the software now allows disabling chart subtitles and enabling floating breadcrumbs, so they can be viewed inside or over the image on screen and no longer on top of it, which used to waste the space of a whole line.
Clearer visibility is also the goal behind another new feature of EPM 7.0: The dashboard home can now fit the whole screen, using up the monitor space. This is a very useful resource for users who only need to keep track of the dashboard, and not to access the editing tools usually located to the left/right of the screen. Additionally, it allows highlighting one or more lines in the datasheet to alert the user of any piece of information that requires their attention.
For further information on the features presented here and more, check out this video or the Release Notes.
About Elipse Plant Manager
This platform offers excellent availability and usability of industrial data, in order to identify improvement opportunities, lower costs, increase products quality, and gain higher operational efficiency. With EPM, it’s possible to collect data from several different sources, add context, and store it efficiently, which results in high performance for recording, querying, and analyzing.
About Elipse Software
As a player in the international market for the past 39 years, Elipse Software develops powerful software tools for real-time management of industrial processes, energy, wastewater, and infrastructure. Compatible with hundreds of different systems and devices, Elipse products turn data into strategic information and undergo constant upgrades for better operational efficiency, scale gains, maximized yields, and minimized losses.
