Check out the latest developments for Elipse drivers
To better integrate our platforms with several types of equipment and automation systems, we at Elipse Software present a portfolio that currently offers more than 490 different drivers. We focus on developing new drivers on a regular basis, as well as on improving and adapting the existing ones for projects that require customized needs.
UPDATES:
Driver Ictel CT850 v1.0.5: driver for communication with the telemetry and telecommand central developed by Ictel. The latest version shuts down any attempts at inverting Block/Release setpoints at Auttom centers.
Driver Alstom BAC v2.0.9: driver used for data exchange in traffic control and train signaling applications at the São Paulo subway system. Master profile [Case 39144] was reviewed for this version.
Driver Elipse GenericProtocol v1.0.4: driver for integration with proprietary or customized communication protocols. It is recommended for users whose equipment works with protocols that are not covered by the standard Elipse Software drivers. This version allows sending fixed frames, with no data fields, via a Tag Send TX Frame. Additionally, frames with a single data field are now displayed as Simple Tags in the Tag Browser, instead of Block Tags.
Driver MQTT v1.0.43: connects devices of the Internet of Things (IoT). This version features support to Sparkplug B (more details in the story). An intermittent failure was fixed for this version.
Driver STATTUS4 Ada v1.0.2: this driver works with Ada System, developed by the Brazilian company Stattus4, used for water distribution networks to provide communication between physical devices such as pressure and flow sensors. This version supports writing values and commissioning devices.
Driver EnronModbus v2.0.15: driver for communication with equipment implementing the “Enron Modbus” (of the former Enron Corporation) variable of Modbus protocol, which is very commonly used in RTUs and measurement devices in the oil and gas industry. This version’s new feature: parameterization for “Table” and “Record Number” in historic collections, via Write Tags.
Driver Unitronics Vision 280 v2.0.2: driver for communication with Unitronics’ OPLCs (integrated PLC + HMI), covering models M90, M91, and Vision series (of which Vision 280 is a part). This version’s new feature: Inter-frame Delay option was added to the driver’s properties window.
Driver Modicon Modbus Master (ASC/RTU/TCP) v4.0.16: driver for communication with any device supporting Modbus protocol. Works in master/slave mode with the device, and can communicate with any ASCII, RTU, or TCP/Ethertnet formats. This version supports “Auto Demotion” configuration in run time.
A comprehensive list of all Elipse drivers and their corresponding documentation is available for download at our website. Check out the one that best suits your needs!
