Check out the latest developments for Elipse drivers
To better integrate our platforms with several types of equipment and automation systems, we at Elipse Software present a portfolio that currently offers more than 490 different drivers. We focus on developing new drivers on a regular basis, as well as on improving and adapting the existing ones for projects that require customized needs.
NEW DRIVERS:
Ictel CT850 v1.0.1: driver for communicating with the telemetry and telecommand central developed by Ictel.
OSIsoft PI Connector v1.0.1: connects to the PI System to collect data from PI Connectors, which in turn can connect to external sources. The driver enables real-time monitoring and historical analysis of data from PI Connectors to integrate into the PI System architecture developed by OSIsoft (currently AVEVA).
Plot PlotControl v1.0.1: driver for communicating with the videowall system marketed by the Brazilian company Plot Visual Technologies.
STATTUS4 Ada v1.0.1: this driver works with Ada System, developed by the Brazilian company Stattus4, used for water distribution networks to provide communication between physical devices such as pressure and flow sensors.
OPC A&E Server v1.0.1: comprises an OPC A&E server and a driver that sends alarms and events to this server, which in turn processes them and relays them to the clients.
UPDATES:
RSSP-I v1.0.2: driver for communicating with railroad system devices via RSSP Type I protocol. This version features the following update: indication of domain number at N4 parameter of “Power-On Time Counter” PLC tag (N2 = 8580).
MQTT v1.039: connects devices of the Internet of Things (IoT). This version features the following updates:
- Support to version 5 of MQTT protocol.
- Support to newer versions of encryption (TLS).
- Memory leak at data publishing was fixed.
- Priorities window was updated.
- Settings for reconnection to the Broker were adjusted.
- Issues that took place whenever the Broker initiated the disconnection were fixed.
- New settings to Last Will messages were added, which can now be customized via Templates.
Siemens MProt v4.0.37: driver for communicating with industrial networks of the Siemens S7 PLC family (S7-200, S7-300, S7-400, S7-1200, and S7-1500). This version features the following updates: Device field is now automatically added to TagBrowser’s tags; write- and read-bits fixes were documented; and support to tag import from TIA Portal version 20 was added.
Convert TRJTracker v1.0.2: driver for communicating with Valmont’s solar tracker devices (trackers by Convert Italia SpA). This version features the following updates: write tags for the actuator’s position angle, and Automatic/Manual write modes.
SNMP Manager (50 connections) v2.0.27: driver that collects information from network devices, such as switches, routers, servers, and others. It can also change settings to allow creating an Elipse E3 application for monitoring networks and infrastructures from different vendors. The driver supports versions V1, V2C and V3 of the protocol. Support to writes or commands was fixed for this version.
DNP 3.0 Slave v4.0.74: Distributed Network Protocol (DNP) is a communication protocol used in SCADA and remote monitoring systems. It is widely used due to its open standard, which allows any vendor to develop DNP3 devices compatible with other DNP3. This version features the following updates:
- 16- and 32-bit analog commands are now interpreted as int16 e int32, respectively.
- Bug: Data reception system behaved oddly when using “Unify Objects with/without status” option. This was fixed.
- A new option for discarding events before or after a reference date was added.
A comprehensive list of all Elipse drivers and their corresponding documentation is available for download at our website. Check out the one that best suits your needs!
