Check out the latest developments for Elipse drivers
To better integrate our platforms with several types of equipment and automation systems, we at Elipse Software present a portfolio that currently offers more than 490 different drivers. We focus on developing new drivers on a regular basis, as well as on improving and adapting the existing ones for projects that require customized needs.
NEW DRIVER:
ZabbixDriver v1.0.1: This driver was developed to integrate supervision centers like Zabbix, allowing to directly collect and monitor IT infrastructure data in such environments. Zabbix is an open-code monitoring tool geared to IT infrastructure.
UPDATES:
IEC870-104 v4.0.23: this protocol is widely used in the energy, process automation, and monitoring systems sectors. The latest version allows declaring the Stations list via numbers or a range of numbers separated by commas. Example: 3,5-9. In this case, the addresses 3, 5, 6, 7, 8 and 9 are generated. It also features a cache system (in slave mode) and a filter for writing null values when the driver initializes or stops.
ABS v1.0.2 e 1.0.3: driver developed for the communication of ABS Telemetria’s telemetry and connectivity equipment, such as modems, gateways and dataloggers. The latest version introduces protection IDs, limits to the number of connections, and history of all documentation revisions.
Ictel CT850 v1.0.2: driver for communicating with the telemetry and telecommand central developed by Ictel. The latest version fixes the feedback return of a command in Auttom centers, which had been inverted before.
A comprehensive list of all Elipse drivers and their corresponding documentation is available for download at our website. Check out the one that best suits your needs!
