Check out the latest developments for Elipse drivers
To better integrate our platforms with several types of equipment and automation systems, we at Elipse Software present a portfolio that currently offers more than 490 different drivers. We focus on developing new drivers on a regular basis, as well as on improving and adapting the existing ones for projects that require customized needs.
UPDATES:
Driver Modicon Modbus Master (ASC/RTU/TCP) v4.0.15: driver for communicating with any device supporting Modbus protocol. Works in master/slave mode with the device, and can communicate with any ASCII, RTU, or TCP/Ethertnet formats. Option for communicating with Slaves in Auto-Demotion mode was implemented in this version.
Driver Modicon Modbus Slave v3.1.7: This version features the following updates:
  • Support for callback readings and Tag configuration via Strings was added.
  • Support for String Hexadecimal format was added to datatypes.
  • Configuration to sort out bytes in data was added.
Driver MQTT v1.0.42: connects devices of the Internet of Things (IoT). This version features support to Sparkplug B. Fail at connecting SSL to encrypted private key was fixed for this version. Further details at the story.
Driver VBScript v1.1.15: driver that allows executing code as an independent process that can interact via reading or writing tags. Version 1.1.15 features password-protected fixes for correctly executing VBScript.
Driver Novus Field Logger v3.0.5: driver for communicating with FieldLogger device (Novus’s datalogger). Fixes for collecting data larger than 65,000 items were added to this version.
Driver Panasonic Welding Robot v1.0.2: driver for communicating with Panasonic welding robots. Help documentation was updated for this version.
Driver Siemens M-Prot (PPI, MPI, ISOTCP) v4.0.38: driver for communicating with industrial networks of the Siemens S7 PLC family (S7-200, S7-300, S7-400, S7-1200, and S7-1500). This version features the following updates:
  • Information in message boxes regarding Tags import errors was improved.
  • Error class interpretation was added to code 86h.
A comprehensive list of all Elipse drivers and their corresponding documentation is available for download at our website. Check out the one that best suits your needs!
