SAAE (which stands for Serviço Autônomo de Água e Esgoto, or WWAS - Water and Wastewater Autonomous Service) uses the Elipse platform to monitor, remotely and in real time, the municipality’s system; previously, this action could only be performed in person, in its operational units, daily for distribution and monthly for water production
SAAE (Serviço Autônomo de Água e Esgoto, or WWAS – Water and Wastewater Autonomous Service) is the local authority responsible for executing and exploring water and wastewater services in Marechal Cândido Rondon, a municipality in the countryside of Paraná, in the south of Brazil. In order to automate the local water supply system, SAAE has decided to adopt Elipse E3.
The company has adopted the solution developed by Elipse Software mainly due to how easily it can be adjusted, improved, and expanded upon. The platform was implemented in SAAE by Alfacomp Automação Industrial.
Remote stations and Elipse E3 communicate via Modbus protocol, through radio networks operating on the 900MHz range. These radio networks are illustrated on a screen, where each station’s communication time with the software can be monitored; the screen also allows editing communication parameters such as read and write retries.
Elipse E3 allows SAAE to monitor and execute commands for the 31 units of the municipality’s water supply system. To do so, the software provides each unit with its own screen, through which it’s possible to supervise level, flow, pressure, voltage, and current that are measured and recorded by the PLCs in the telemetry panels installed in each remote station.
On the same Elipse E3 screen, it’s possible to follow the water pumps’ operational conditions: malfunctioning, under maintenance, or active. Additionally, it’s also possible to track or reset the time period during which the water pumps will work, and to view and edit standard settings for voltage, current, and pressure.
This control also applies to water level settings in the reservoir, which can be adjusted to automatically turn water pumps on or off as needed, in order to ensure supply and reduce waste. For rational use of water and power, Elipse E3 enables selecting which stations will work in peak hours according to demand.
The software displays the overall and distinct water levels and volume, thus providing access to adjustable standard water settings in each reservoir. Also monitored are the flow levels measured in the water pumps, both overall and hourly, as well as the automation system’s scan time for each unit.
The Elipse solution can also issue reports for the event, histories, and alarms at user-defined periods. For alarms, specifically, if any pre-set value is not being respected, the software will warn operators via visual and sound signals.
Finally, the software allows the units’ performance analysis to be visualized as charts. Both reports and charts can be exported to PDF or Excel, and are valuable tools for auditing and control.
Elipse E3 allows SAAE to monitor, in real time, all 31 water supply units in Marechal Cândido Rondon. Then, the operator is briefed by the software of any inconsistencies in the system, such as water leakages, which enables them to act more quickly to solve the issue.
According to SAAE’s Operation’s Control Center, before Elipse E3, they had to wait for the community to report directly to them whenever their houses had suffered any water supply occurrences. This is no longer the case: now, the operators at SAAE can act more readily to detect any failures and maintain the system via Elipse’s platform.
Check out the list below for other important benefits obtained by SAAE with Elipse E3 in this application:
Client: SAAE (Serviço Autônomo de Água e Esgoto)
Systems integrator: Alfacomp Automação Industrial Ltda.
Elipse product used: Elipse E3
Platform: Windows 10 PRO
Number of copies: 4 (1 E3 Server + 1 E3 Viewer Control + 1 E3 Viewer Only + 1 E3 Studio)
Number of I/O points: 1500
I/O driver: MODBUS RTU
